May 17, 2025 #1 S spikeyz0 Active Member Joined Dec 27, 2024 Messages 37 Reaction score 15 Location Maryland Rating - 0% 0 0 0 Contact seller I got a 1971 904 transmission with a 318 I need the kickdown rod from the transmission to the manifold bracket
May 24, 2025 #2 JoeDragster FABO Gold Member FABO Gold Member Joined Jul 14, 2004 Messages 771 Reaction score 194 Location Longview, Texas Rating - 100% 12 0 0 I have a 71 904/318 kick down rod for the carb and accelerator pedal. Are you needing the part that attached to the tranny ?
May 24, 2025 #3 JoeDragster FABO Gold Member FABO Gold Member Joined Jul 14, 2004 Messages 771 Reaction score 194 Location Longview, Texas Rating - 100% 12 0 0 This was off a floor shift car I parted out. The other parts are on the tranny but I didn’t seee a rod or linkage from the tranny up to the accelerator linkage. I have a box full of linkages but it’s a guess what is what
May 25, 2025 #4 S spikeyz0 Active Member Joined Dec 27, 2024 Messages 37 Reaction score 15 Location Maryland Rating - 0% 0 0 0 I need the piece from the throttle mechanism to the transmission it's two pieces of linkage with a swivel piece that bolts to the trans
May 25, 2025 #5 JoeDragster FABO Gold Member FABO Gold Member Joined Jul 14, 2004 Messages 771 Reaction score 194 Location Longview, Texas Rating - 100% 12 0 0 Ok. I know which piece you’re talking about. There is a piece like that in the crate in the shop. I’ll pull it out and shoot a picture
May 26, 2025 #6 JoeDragster FABO Gold Member FABO Gold Member Joined Jul 14, 2004 Messages 771 Reaction score 194 Location Longview, Texas Rating - 100% 12 0 0 Does any of these bear a resemblance on what your looking for?
May 26, 2025 #7 T townsend Well-Known Member Joined Feb 8, 2021 Messages 826 Reaction score 680 Location 46601 Rating - 0% 0 0 0 This photo includes the parts you are looking for. Use the eBay photo as a reference. https://www.ebay.com/itm/3827976774...SvxWbocaK7DdUsHLCpSvKwyRrL|tkp:Bk9SR7itkP3hZQ Last edited: May 26, 2025
May 27, 2025 #8 S spikeyz0 Active Member Joined Dec 27, 2024 Messages 37 Reaction score 15 Location Maryland Rating - 0% 0 0 0 Yes thank you that's correct one I found a set
