A 833 I.d.
alkyfish69
New Member
Hi. I have a 18 spline A body four speed with liberty pro shift parts. Just wondering if any body can I.D. the case numbers for me. Casting, c 99129 Stamped on the pad. PP8332854. 0282 :read2:Thank's.
build date 2854 = 5/21/1969
Could be a 69 or 70 transmission. Any numbers on teh same pad you got the PP8332854 numbers. Likely just above them. That may have the designator for what year car it was installed in.
Thank's. There is no other numbers on the pad. I know this is a hemi unit, but it has the a body tailshaft. Thought it might be an old super stock trans.
What you have is a 1969 18 spline, which probably has the dual shifter mounting pads. It was built May 21 1969. PP833= 833 trans, 2854= build day May 21, 1969. Let me know if you want to part ways with this unit, as my 69 440 4spd charger needs one.
Thanks, Dan
