well I managed to dry fit it in the hole (w/out trans) so far so good.
I used c body manifolds with some slight grinding on the m/fold at the steering shaft coupler.
As for the shoemaker mounts, the r/t side was two inches to thick, so I used the old B body mount bracket, drilled a center hole for the sandwich mount and voila! its in.
By the way, I kept the power steering, It clears the gear and hoses yet will need a heat shield.
For starter I'll be using a starter off a 96 ram which is smaller.
Cant wait to start it up!
Keep you updated.
Dan
