[SOLD] A body 4 speed set up
mattsmopars
Cookeville,TN
I have an A-body four speed set or atleast most of the parts needed to do a swapwith a small block. Included is the A body slip yoke trans no rust or broken gears inside, alluminum 10.5" small block bellhousing, inspection cover, small block clutch fork, SB A-body z bar, A body pedals with spring, rod from pedals to Z bar, A-body hump that needs some work along the bottom edge, but other wise nice, and a 10.5" neutral ballance flywheel. Flywheel is not in the pictures, but I can get one.
Located in middle Tn and can be picked up. Also I am going to try my best to go to the Indy swap meet and I would bring it if prepaid. $750.00 cash gets it all.
Please PM me if interested, and I can get other pictures as well if needed.
Thanks , Matt
Here is a couple pictures of the flywheel. It looks to have been turned, and eith lightly used or not used. I had to take a little sand paper to it to get some flash rust off of it, but the turn marks are still present.
The 4 speed trans also has the hurst shifter mount still on it as well.
Matt
