If the shifter tower has a bolt on handle you can probably get a different handle that has the proper offset so it can be used with a console.
You basically need a shifter tower, mounting bracket, & linkage with rods & tabs, that are all made for an A body Mopar trans. Then you bolt on the handle for console or non-console. The difference between the console & non-console handles is that the console handle has 2 right angle bends in it. The first one bends the handle toward the center of the car. The second bends the handle straight up so it will come up through the hole in the center of the console.
