Landons65Dart
Proud Mopar Owner
Early A-body small bolt pattern. Not sure what gear ratio(possibly 4.10). The rear end is missing the brass v-block for the brake lines and the internal drum hardware, but I have the drums. No leaks. Had 90,000 miles on it when I replaced it with a posi 8-3/4. Would make a good roller rear end or stock build restoration.
I will deliver if you pay for my gas.
