Tsully
727 1973 TorqueFlite less than 300 miles on rebuild. It was in my 69 Cuda when I bought it last year. I’ve put an overdrive in it and I’d rather it go to someone who will use it rather than it just lying around. It comes with a 440 source flex plate and stock converter, tail shaft is for an A Body as it lined up perfect with the trans member. It does need a front seal as it has small leak when it sits, I think whoever put the converter in may have pinched the seal. I haven’t pulled the converter to check, it feels like it has a shift kit in it as it has firm shifts and does not slip at all. Let me know if you have any questions. I’m located in St George SC and would prefer local pickup if possible.
