[SOLD] a body 8 3/4 complete rearend
hotrod360andy
Minnesota
Rating - 0%
0   0   0
8 3/4 rearend for sale. Rearend is complete with 4.56 gears, clutch type posi, strange axles with green bearings. Bolt pattern is 5 lug by 4 1/2 inch pattern with 3 inch long wheel studs. Rearend has 2 sets of spring perches. First set in the stock a body width the 2nd set of purches are set for when the springs are moved to the frame rails to make room for more tire. Selling this so I can upgrade to a dana. Rearend works great and has been in my 1976 Feather Duster for about 10 years. The car is a 10 second car and it has always launched perfectly straight.
Rearend gears were set up by Sheradon Performace and the also welded on the extra set of spring perches.
I am unsure measure the distance from center of spring perch to cenet of the other spring perch and can check the measurement on my perches and see if it would work. Or you can simply install new spring perches where you would like them. Let me know.
Andy
