mattsmopars
I have a complete original A-body rear with a 742 case 3.23 clutch type suregrip in it. I removed the rear from a 1970 duster. It is complete with housing, small bolt pattern axles, backing plates with correct drums, 2-shock plates, 2 of the original u bolts, complete suregrip chunk, and the E-brake cables. The only issue that I see is that one of the bolt holes on the yoke has been drilled through and a bolt and nut used. Will also need cleaned up. $650.00 for it all. It is located in middle, Tn and can be picked up, or shipping worked out.
Send me a PM if you are interested.
Matt
Matt
