[SOLD] A body 8-3/4" high strength axle package
1320racing
Morehead City NC
New high strength 30 spline axles with green bearings installed, stock length for 489. stock length studs, 5 on 4-1/2" Changed direction and went with a B body rear. Purchased from Dr. Diff, installed in housing and removed with zero miles. Paid $340 shipped looking for $240 plus the ride.
For clarification, axles measure 28" from outside face to end of shaft. Length of splined end is approximately 5-7/16" overall. Fitted with MO-400 green bearings that are 2.875" diameter. Wheel studs are 2" long stock length and are hex head, not round - so I'm assuming they are thread in. 5 on 4-1/2" bolt pattern. I've read an A-body 8.75" housing should measure 52.625" but please double check. Thanks.
Hold on folks,
Just talked to Ralph about the axles and I need to talk to Cass at Dr.Diff tomorrow (Monday) to validate these will work for me. Pretty sure they will but if not next in line is up at bat.
Hemi
I am also taking myself out of line. Sticking with my small bolt pattern for now. Thanks.
