A Body 8.75 Rear End
aimplus
Member
Rating - 0%
0   0   0
Need an 8.75 rear end to go into a 72 Demon. Needs to be big bolt pattern. Pristine not required, rebuildable is fine. Contact me with the specs/gear ratios you have.
I am in Arizona so will work out shipping when we make a deal.
You realize that a BBP 8.75 A body rear will likely have aftermarket/resplined axles in it.
I have an A body rear with SBP complete with brakes.
Have a set of BBP yukon A body axles. Might have some BBP brakes.
Got 3.91, 3.23 and 3.55 sure grip pumpkins.
The 8.75 a body rears aren't cheap, housings alone go for in the 275-300 range out here. Add in the special stuff that you want which isn't normally on them and it adds up quickly.
The conversion kit I am looking at will run about $1300. If I can get a rear end with all this already done, I'll seriously entertain the thought.
Since I want this car to have some balls, but still be a good daily driver I thought the 3.23 gears would suffice.
What are you asking for your set-up? If you don't want this to go over the chat then e-mail me at aim_plus@yahoo.com
Sent you an e-mail.
I may be able to deliver it to west side Phoenix, no charge.
I have a 8-3/4 complete, drum to drum, for an A-body. I'm in Denver. Do you want more details? I'll go unbury it at Storquest.
Jim
I'm interested to here what you have. Give me the details.
Thanks
