[FOR SALE] A body "Big Bolt" (rear and disk brake) kit. ready to bolt on
swing69
fightin' socialism
Central Socialist NJ
I assembled the following parts to convert a 1967 Dart to a large bolt pattern. but alas......the car is gone and the parts are still here.
Package deal - all or nothing. Will pallet and drop off to a Fastenal for $50 additional...you pay all the freight.
For the rear:
1973(?) 7.25 open rear with 2.76 gears. NO NOISE when last run. CLEAN and consumables rebuilt. OEM drums blasted and rustoleum painted, Housing, cover, stop and backing plates cleaned and rustoleum painted. New shoes, hardware, wheel cylinders. New steel brake lines and new hose. New 67 Dart ebrake cables.
For the front:
1973+ A body Disk Brake spindles. Blasted and painted. Includes lower ball joint bolts.
1973+ A body UCAs. stripped and painted. No BJs or bushings.
1973+ A body eccentric bolts (4) blasted and painted.
1973+ A body brandy new rotors in box. Aimco 5314 or BD60463 (2)
You will need to buy readily available parts to do the brake/spindle swap up front: splash shields, bearings, dust cap, loaded calipers, front hoses, drum disk prop. valve and drum disk master cylinder.
$500 obo. Parts in central NJ. Prefer pick up near exit 8 of NJTPK.
