A body brakes
Busterme
Worcester ma
Can't wait for the weekend to see if I can finish my front disc brake conversion on my 67 barracuda notchback .currently I think I have some kind of blockage to left side caliper? Rigt side bleeds fine but not much from left side. I'm gonna dig into distribution block and left break line. Hopefully I'll find something. I ordered new front SS steel brake lines and proportioning valve but it will be weeks before I get them. Would like to see how she drives with new brakes
Check the flex hose. I helped a friend get his Dart back on the road and had a similar problem. The metal part of the flex hose had rusted and was blocking the fluid passage.
If the lines and caliper are new, make sure the hole in the bleeder screw is drilled all the way thru to allow fluid to pass.
