[WANTED] A body colum shifter linkage
Veryfastdart
Hampton NH
I am looking for a body column, shifter linkage and kickdown linkage for a 318 or 340. I have a 727 SB
Not sure if linkage from a 904 will work but it looks like the mounting is the same?
Thank you.
Thank you.
Some of the shift linkage is the same, some isn't. Most of the kickdown linkage is different between a 2bbl and 4bbl. If you have a 340/727, you pretty much need a set off that, or a 360-4/727 from an A-body. Look in a factory parts manual for your car to see which parts are the same as other models.
Great
Thanks for info! Sounds like it’s going to be a choire so maybe Locar???
