1bad360duster
- Joined
- Dec 2, 2009
- Messages
- 303
- Reaction score
- 153
had two cracks. one in the back(see pic) and one in front. also alot of scuffs/nicks. evercoat maxim 2 part plastic repair was used on the cracks and sanded with 600. then cleaned entire console with gray scuffpad and sem soap/ then sprayed sem texture paint over entire console. sanded it like it says, but when painted over the high spots from sanding stayed shiny making the console look blochy. then it was redone but spraying texture paint -grey scuffpad-then one light coat of texture -then black sem paint dye direct over the texture paint. i think it came out well. sent out the top for chrome and then applied new woodgrain decal. just need to glue the carpet on then make a trim piece for around the shifter.
![007-10.jpg](http://i297.photobucket.com/albums/mm231/romanjello2/007-10.jpg)
![001-12.jpg](http://i297.photobucket.com/albums/mm231/romanjello2/001-12.jpg)
![028-4.jpg](http://i297.photobucket.com/albums/mm231/romanjello2/028-4.jpg)
![035-4.jpg](http://i297.photobucket.com/albums/mm231/romanjello2/035-4.jpg)
![038-3.jpg](http://i297.photobucket.com/albums/mm231/romanjello2/038-3.jpg)
