A body disc brake spindes
Thanks, I will go ahead and place a bid then.
Yes we are a shop and deal with MPB from time to time. I don't need a kit. As I will be building my own upper control arms and using Wilwood 4 piston calipers or Viper calipers. Just need a starting point to convert to larger bolt pattern.
Thanks Tim
Thanks Tim
Good deal. As they say, bid with confidence.
Where are you going to get the caliper brackets ? They are not there in the pictures. Failed to mention that but bid with confidence anyway. Any one who has a set will not split them from there spindles. These spindles are useless without the brackets. Make sure he has the brackets they do not come with the calipers. Steve
Thanks Steve, The brackets are not a big concern as I will be using a aftermarket caliper. I will make a set of brackets and spacers to run either a Wilwood or Viper caliper with 13" rotors.
Tim
