airgrabber
Factory setup with the push in style handle. I removed the handle, disassembled the mechanism, bead blasted everything, cleaned and moly greased it and reassembled it. Two spot welded tabs on the stick handle shims popped off - replacements available from vendors out there, use as-is, or use the shims and rubber bushings and drill and bolt the handle in place like the non factory units. Chrome on stick is driver quality, some copper showing thru on the pass side of it where it bends up. Hard part to find. $275 firm plus shipping from Florida, should be able to ship in a medium size flat rate priority mail box. What you see is what you get. USPS money order or paypal - either F&F or 4% of total with shipping to cover their costs.
