Nice solid front and rear full frame rails and crossmembers carefully removed from a 76 Duster. Frames should fit all 73-76 A bodies as-is and 67-72's if you add the bumper bracket mounting nuts.
Front frame rails include the UCA and shock mount brackets.
Rear frame rails include the leaf spring shackle mounting area and front spring hanger mounting area.
Front frames $140 each, $260 set.
Rear frames $130 each, $240 set.
Torsion bar crossmember $120
Shock mount crossmember $80
Rear frame crossmember/panel $80
Parts in Phoenix, AZ 85042
Shipping available
Greyhound, UPS, etc.
Local pick-up works too!
Shipping available
