Logan75
Member
1971-73 A Body manual steering box 24:1 ratio. It will need new shaft seal at pitman arm end. Power steering column is for a floor shift car, has a key, broken tab on turn signal switch comes with lever and screw. Both electrical plugs are in good shape no steering coupler included . The steering wheel is factory 15” without horn switch or button pad, has two cracks at hub area. $325.00 for all plus shipping will ship in two separate boxes. Would like to sell as a set,Located in central Nebraska.
