[FOR SALE] a-body Master Cylinder Dr. diff. Aluminum Master Cylinder $85 + shipping
72dustervs
Winchester, Kentucky
15/16" bore master from Dr. diff. It was mounted once and bleed system but never ran , it is in new condition , I ended up going with the 1 1/32" bore master from Dr. diff. you will need to buy the adapter plate but it will mount just like original with the adapter plate . I bought for 72 duster power brakes , believe it fits many a-bodys you can check there site
curious to know the difference in pedal feel between the two bores with power brakes. are you a disc/drum setup on your 72?
I originally bought master cylinder , for my booster for drum brakes front an rear , I ended up converting to disk with same booster , I contacted Dr. diff. after I had purchased and said if I had disk front an rear would have been better , but it would work with my booster but could possible have pedal travel , so I just purchased the other size master cylinder for my setup .
This will work on many applications as it gives more pressure , the Dr. diff. site has info and you can contact them with questions I cannot answer
