[WANTED] a body ram rod bracket
dust-u
anybody have any info . on a holy grail ram rod bracket for an a body. pics ? dimensions?.secret map to the treasure? I know this has been asked a million times,but I really miss the ram rod I used to have. and since I repaired the gigantic hole needed to run the mr g v gate.i was running ,only the original ram rod is what I would prefer. I have two complete mr g's with linkage if anyone is seeking one? any help out there?:burnout:
Never had one in an A, but like you I wish I did or should I say I do....
Loved that shifter in my Super BEE!
I made my own bracket with alot of trial and error but if I ever found the dimensions for an A body I would copy that as well. I don't remember any dimensions anymore and it's installed in car now
I took a picture for you.This is a true A Body one
Here is one with both kinds of rods that they came with.
I put one in I found on eBay while doing a 4-speed conversion.
It did require a small amount of trimming to the cross member due
to the strait rods. It has a A-body specific mount or adaptor bracket
to mount it to the tail housing. It ends up at the rear side of hole for the boot.
I haven't welded my tunnel in yet so I can just move tunnel back some to center
the shifter in the opening. Over all it worked but not exactly a bolt in like the factory parts.
Not what I pictured in my brain. My Bee had a extension bracket that seemed much longer and moved it back and up. That looks like the bracket is quite short. Does have a black reverse knob they way I remember!
Thanks for posting hope it helps the OP!
