sbh126
Will the tailshaft and housing from an overdrive 833 work on a 68 b body 833? what other parts are interchangable?
Main case and GEARS will allow a new extention housing and shaft to be swaped. The key is you must get a NON overdrive mainshaft to use with a housing. Bearings are not the problem, you can use either 308 or 307 bearing front/rear. The early gears cant be used on the OD shaft.
Or just start with a real A 833 trans.
Which I happen to have, rebuilt even, for the large yoke.
No, some of early 383's had 307's
even b body 833's?
I have 2 different 4 speeds. One is an overdrive unit for an a body. The other is a b body 4 speed. I want to put a 4 speed in my duster behind a 440. I dont want to use the overdrive because it wont hold up to the 440. But the b body 4 speed wont work without a tailshaft for an a body.
Yea, but probably not past 1968. I have one I bought for the main housing to swap an OD gearset into. That way I can swap an OD into my 66 without changing bellhousings for highway cruising. It has the slip yoke so must be 65 up? Just looked at Original bellhousings at the Brewers Performance website, Looks like all big block and even Hemi bellhousings till 1967 used the small bearing retainer. I guess you learn something new every day.
