berwaldg
cudasforever
Well I have this Mopar fan motor......but it is quite a conundrum. I removed this motor from the under dash a/c system on my wife's one-owner '68 Barracuda; she has never had it replaced. It is a double shaft motor and with 12 v applied, spins like new at 3850 rpm. The motor is quiet and the bushings seem fine with almost no radial play and very little end play. The motor has no markings on it, but the original part number is supposed to be 2870270. I removed it because it didn't seem to move enough air, and replaced it with an NOS motor. The new motor spins at 9800 rpm so I can only conclude there is something wrong with the one I removed. Is it possible that it has a bad winding? In that case is it re-buildable? Or is it possible that the motor is fine, just used in the wrong application?
In any case I would like to find a home for the motor. The new motor was $165 so I would like to get $10 for the old one plus the ride.
