Peter L
Active Member
Finally tracked down all the missing a/c pieces for under the hood of my '69 Barracuda. Looking for pictures of the correct hardware that holds down the steel lines and dryer to the inner fender. Also the condenser. I have some of the clips still on the steel line, but not sure if they are correct. Are they phillips screws, small hex washered bolts, are the clips all steel or do they have a coating of rubber? I'm starting from scratch, so any help would be greatly appreciated. Going to Columbus in a couple of weeks so I'll hit one of the hardware vendors.
Thanks, Pete.
Thanks, Pete.
