convx4
I have a 70 dart with a slant six and factory A/C . I changed the K-member to the spool type motor mounts when I added disk brakes. I cant seem to be able to remove the valve cover because the A/C heater hoses are in the way. It looks like if I remove the motor mount bolts and drop the motor down I will have to remove the fan shroud, and sill not know if there is enough room by the firewall to remove the valve cover. If I try to drop the trany mount then I have to remove all the shift linkage. I don't want to open the A/C system if there is a trick I can use. Any Help would be Appreciated.
Bill S
Convx4@yahoo.com
Bill S
Convx4@yahoo.com
