mopowers
I tried bench testing an original A/C switch like the one in the picture below. When I apply vacuum to the vacuum port with all other plugged, there is an obvious leak in all button positions. I'm sure the leak is small, but I'd assume the engine would not like it. How tight are these switches supposed to be? Is there an acceptable amount of leakage?
Also, I've seen NOS ones on ebay as well as reproductions from Standard. Would a NOS switch be prone to leaking as well because of it's age? Given the choice between NOS and new repro, what would be better?
Thanks!
Thanks!
