My SB has been running sweetly, no A/F issues, no pump shot problems (AFB 750) or Fuel delivery problems - its a well sorted car (finally) .
Recently I fitted a viscous fan, and blocked the heat crossover on my intake.
The car now runs SERIOUSLY cooler, to the point where even after 15 mins driving, the car "flat spots" at around 4000 rpm at WOT, and appears to be leaning out.
I richened the mixture by using richer metering rods - and it seems to have fixed the problem
BUT - I want to double check - :read2:
Am i correct in assuming that the cool running engine is causing poor vapourisation of the fuel?
If so -
What is the most appropriate fix?:
A.- RIchen the mixture (like I have done)
or
B. - change the thermostat so the engine runs warmer in our winter
As you can imagine, here in Australia we rarely have to worry about engines running too cold....so this is all new to me.
If so -
or
