sparkie573
Hey guys, I posted this on fbbo but I know there is a lot of info over here.
I have a 70 roadrunner project and am researching a 5.7 / 545rfe swap. I know that I'll have to do some tranny tunnel surgery but I have a few other
i am most likely going to stick with the stock style suspension and I am wondering if there are any other mods I need other than notching the k for the oil filter?
Also I would like to stay with the stock power steering box if I can, is there a stock exhaust manifold that will work with this configuration? I have heard that the jeep or truck manifolds work, is this true?
I'm thinking that after getting it all in and running that I may go with a single turbo setup but that is later on. I'm wondering about using the stock computer system with this combo, will it hold up
Anything else I need to worry about?
I'm looking into finding a rollover vehicle pretty soon and just trying to make sure I have all my info correct as I'll probably go with an 04-10 ram 2 wheel drive and using as much as possible from it.
Thanks all any info is great. I've been trying to soak up as much as I can.
