71dustar
I tore apart my steering box to replace the worm gear (20:1 now) and also the pitman arm. With everything mounted in the car, I have a considerable amount of dead space in the steering wheel. This is due to the mesh between the pitman arm shaft gear and the worm gear. Is the pitman arm shaft replaceable or is there another solution?
