[WANTED] A500 42RH transmission in Arizona
My intent is to use it behind a 5.9 Magnum in a 1941 Plymouth. If I get a used one, I will get it rebuilt for my specification/need. As for the lock up or non lock up, I want to have the option of overriding the hydraulic setup via toggle buttons for the lock up and for the overdrive.
The car is going to be a street driven, so my goal is to make it both strong enough for use behind the 5.9 and handle spirited driving if it ever occurs.
I pulled my 42RH out of a 5.9 Dakota at the Pick a Part up here in Prescott area.
It was $125 for the trans, converter and 7290 drive shaft yoke.
I think you might change your mind on the toggle switches as its pretty easy to make an automatic shifting system for OD and lockup.
