jrlegacy23
68 Barracuda
I just got an overdrive trans for 1968 Barracuda. It is a 1993 Dodge A518 (46RH) transmission that was pulled from a half ton van. The tranny was working fine and then started losing reverse when it is hot. When the engine is cold it operates fine; but once up to temp, the reverse in the tranny doesn't work at all.
Any tranny guys out there have an idea of what may be wrong?
