I’m going through a refresh on my 67 A727 that includes swapping out the original 3 friction drum for a 4 friction drum (in order to run 5 thins) and just received it from A&A. The bushing has been installed slightly proud of the bottom chamfer vs flush with bottom chamfer (as shown in various manuals) but my original 3 friction drum with its original factory installed bushing has it installed a little further into the bore beyond that chamfer.
The last time I rebuilt it, after checking and adjusting endplay, the 3 friction drum bushing pretty much fully rides on the reaction shaft.
Now with the 4 friction drum bushing installed, as it is, will have less engagement with the shaft, regardless of what selective thrust washer is used to set end play.
I’d think installing the narrow bushing initially for mock-up in order to set endplay, then driving it further as needed so there is full contact with the shaft would be a good idea? More load carrying or not a concern??
Factory original bushing/3 friction drum:
4 friction drum as received with pump shaft installed:
Bushing installed in 4 friction drum:
3 Friction drum with pump shaft installed with thrust washer for correct endplay:
Manual (Carl Munroe book) Instructions for Bushing install:
