A833 4Speed 70' Charger
It would be a lot of trouble to get it in there. The B-body tailshaft puts the shifter in the wrong place for an A-body. The '63 speedo gear and end of the cable won't work in a '70 trans. And you'd have to get a new driveshaft made to bolt up to the later output on that trans - it has a regular U-joint instead of the ball-and-trunion joint on your '63.
