Hi,
I'm searching for a a833 trans for my Valiant 69 project.
So far I have managed to buy a 318 (from a 74 roadrunner) engine with an a230 (that doesn't fit) and a flywheel with it.
Also I have found 2 A833 trans for sale near me.
One is from a 64 Valiant with shifter, shift rods, bellhousing, clutch fork and as I understand a drive shaft (from a 318cid ).
The othe one is a A833 with a bellihousing nothing else. The owned doesn't know from what car it's from, but I seems to by a A body trans with a ID number: C-96561 H (from a 318cid ).
The price is the same.
Because I don't live in USA those are my only 2 optionst at the time and because those trans cost big bucks around here I don't want another trans just to sit in my garage.
Both are from 318 car.
So my question is which one to choose and why?
As I understand the 64 trans has a thing called a "ball-and-trunnion front U-joint". Does this cause many problems even if I get a driveshaft with my car.
Does the drifshaft even fit my 7 1/4" rear axle (have a plan to swap it in future anyways).
Also does the 64 trans need some kind of a different z-bar etc ?
thanks.
I'll add some pictures of the 64 trans:
thanks.
