CirusP
Member
A 2wd 833 OD will do you little good unless you want to go out and find/ adapt a divorced transfer case "from out of something else." Years ago Advance Adapters did make a bearing adapter to convert some types of transfer cases into "divorced."
I don't see it. It's still 4 gears and if you have a 2 speed transfer and pick the proper final gears a conventional 4 speed would be fine.
or drum up one of the small Dakota 5 speeds used over the years, already set up to bolt to a SB / magnum and a Dakota transfer case. For the life of me I cannot remember, maybe a NV3500?
Thats a good option, but the idea was to use the stuff i have laying around. But yeah, that would be optimal. I'll look up for AAdapters to see if they still do. Thanks.
