Schyrjajew
Slant 170 Val with the A904
Since we got it, I immediately noticed things:
For example, when you put it in reverse, it immediately makes a dull sound (like someone hitting an empty oil barrel with a rubber hammer).
The car shifts hard and jerkily. It is not only clearly noticeable, but also unpleasant.
Especially when downshifting, you are "moved forward".
What can this be? I have always had manual transmissions before.
The colleague said it could be the universal joint at the rear of the driveshaft, but that will hardly be only that. Should I change the oil? Oil level is ok.
