no,there should not be large air leaks on any piston on either the forward or direct. The metal rings on the reaction shaft do allow some air bleed, but not enough that the piston doesn't move up.
The outer seal on the direct drum you've been fighting is the seal that can roll when you push the piston into the drum.
