AAR fibreglass hood pin location
SB69GTS
Ontario
Does any member here use a aar fibreglass hood on a 67-69 dart. Im trying to get a pic of under the hood location for hood pins. Need pic for a fibreglass hood not metal hood. Thanks in advance if you can help.
Bolt on hood or lift off? :popcorn:
71 dart and 71 duster. 67-69 never came with hood pins. Both cars the pins are in front of the hood bumper
The avatar 72 Demon. AAR fiberglass 6-pack hood. Looks like the pin location matches Oldmanmopar's cars.
for 70-72 cars there is a dimple in all the fender inner structures where the hole for the hood pins go
No, you still need the hood bumper to locate how far down the hood closes on both sides to allign with the fender top
Just put rubber on the hood pin. Gotta do it anyway to pad the fiberglass from the steel hood pin.
