Seen one and was not impressed with the seam noticeable through the windsheild all the way across the dash. They may have changed since then. But if they didn't I would not want one. Also make sure you get your cora back or you will get someone else's. Rusted ou repaired ar stripped fasteners. Or could even be fiberglass.
I took pads out years ago and wiped them down with vaseline and wrapped them. I have four in the bedroom left. I use them on my builds. I sold some at Carlisle two years ago, Good luck .
I would call them and make sure you get a commitment on what they are shipping. The best thing to do is look or have someone look for you at Chryslers at Carlisle. Nothing like seeing what you are paying for. They are the same from 69-76. Nothing beats a soft original pad.
