Absolute best header gasket
Ironmike
Western Pa
Tired of buying and trying. What is the best header gasket money can buy?
I'm running Indy RHS iron heads and TTI headers. Small block LA stroker.
Somebody please make up my mind.
Have you tried Remflex? There is another that the name escapes me at the moment, I have never used them.
I use the Remflex with no issues yet, and I run cheap headers.
I also use Stage 8 locking fasteners so no chance of the bolts backing out.
One word: REMFLEX!!!! they are totally the best you will ever buy!!!!
I almost bought new headers untill somone here at FABO told me about REMFLEX
You will also find, that with a good header, like TTIs the need for a high quality gasket is not as important. I have seen the cheapest mr gasket white paper ones last for YEARS with TTIs, and only days with the el cheapo headers..
Go Remflex, haven't had a leak with mine.
Remflex it is. Found em online but not sure which ones. My RHS heads have rectangular ex. ports. Looks like I might be trimming them a bit.
By the way, are they copper or what?
I have never used a gasket for my headers .. I only use perma tech hi temp gasket maker....learn that from my friends years ago..thye run high 5's low 6 with no problems:D
No they are not copper. Check out their web site. It will say the material. Call them if unsure what ones to get
Percy's make a soft aluminum one that is re-usable.
It is made from multi layer af aluminum, they will seal about any header, unless it is warbed beyond reason.
