AC bracket
Joseph24251_200
The Mopar Kid
Fayetteville
Hey does any one know and have a pic of what a 360 AC bracket looks like. I think i have the older style 318 bracket and I'm tryin to find out what teh 360 bracket would look like so i can get one. Also would the AC clutch on a older 318 motor and the 360 be the same.
The compressors should be the same. A v twin unit normally called an RV-2, looks like a small harley motor - sort of. The brackets should all be interchangeable as long as you swap all the pieces over from one unit to the other. Clutches should be the same as well. Hope this helps.
