Ac line caps
AN caps should work
I don't believe they are AN. I was under the impression they are SAE. Check the ANGLE OF THE FLARE SURFACE.
AN/ JIC (and you can get JIC at any hydraulics supply outfit) are 37 degrees. SAE (which are common copper/ brass fittings, and used in stationary refrigeration, are 45 degrees.
