Accel Distrib
cowest432
being my first a-body[73 duster] i noticed two problems with this dist,first the firing order is off one[advance] and have no idea the cam besides being hyd[non adjustable rockers],second the plug wires are flush against the wiper motor,,this was a 6 cly that was changed to 340 any idea's
If the plug wires aren't indexed correctly it's because somebody installed the oil pump shaft (that's what the dist. engages into) incorrectly. You'll have to pull out the dist. and lift the oil pump shaft and turn it a notch to get the wires where you want them. If you have the 2 speed wipers the motor on it sticks out vs. the 3 speed wipers where the motor lays flat. I have the 2 speed motor on my Cuda and had to switch to 90 degree plug wire (dist. end) boots to get it to clear the wiper motor.
firing order is right,thanks,,piss poor design on wiper motor,will change if i can
