[WANTED] Accessory brackets
Iron Oxide
Huntsville, AL
I'm looking for small block brackets for a non-A/C configuration to run on a Magnum 318 in my early.
I need brackets for a TRW power steering pump and an alternator bracket. I'm looking for spacers and all associated hardware if possible.
Thank you!
Any idea what they would need to look like?
Other than position? Alternator passenger side high mount, power steering low on drivers side. I don't have any pulleys yet, nor do I have a water pump so I guess I really just need to find a set of matching brackets.
I would get the water pump mounted 1st since that is in a fixed position then look at alt and PS location next and I would think pulleys are the biggest variable so save them for last. Have you looked at yahoo and google photos to get ideas? I don't know if Magnum and LA use the same brackets.
Excellent, let me know![/Q
UOTE]
Here is the picture of what I have.
