TOM RONOLLO
New Member
I am a new member and thank you for this opportunity to ask a question. First of all, I hope I am doing this correctly. I did not know how to continue the thread. I wanted to know where to attach the vacuum supply line from the booster to the engine (or carburetor). I am adding a power booster to a previously manual brake system, I am sure I need a proportioning valve, but where do I connect to draw a vacuum to the booster, and what size diameter hose is recommended. (I guess that makes two questions). Someone said to "T" off the main hose that goes from the valve cover to the carburetor (larger hose). Is this advisable? Either way, thank you in advance for any reply It is for a 1973 slant six automatic valiant, with front drum brakes. I purchased a booster brake kit from Cardone. Also the car has no AC.
