adding lg bolt pattern disc on to 68 valiant
72duster72
castle rock co.
I pulled disc brakes from a 74 a-body. now for the embarrassing question do calipers mount towards front of car or to rear of car if looking from front.HELP!!!
i had the same problem with my 66 cuda when i did the same swap your doing. the research i found though all said you would get less nose dive from putting them towards the rear. Not to mention mounted to the front you can't have a sway bar.
thanks for the help i happen to put them on facing rear. and i did put a swaybar on ,so i got lucky. Thanks again
