C coffeedart67 Well-Known Member Joined May 9, 2010 Messages 1,200 Reaction score 64 Location Southeast South Dakota Jul 30, 2013 #1 I have a question on adjustable proportioning valves, can they be mounted in any direction(with knob facing down)? Thanks
jefflock 69 Dart 408 10.08 best pass so far FABO Gold Member Joined May 18, 2006 Messages 3,515 Reaction score 110 Location Kansas Jul 30, 2013 #2 I had mine on it's side. If it was going to leak it should have in that position. Personally I think you should be ok.
Frank Mopar Well-Known Member Joined Aug 14, 2011 Messages 1,478 Reaction score 936 Location Lackawanna, NY Jul 30, 2013 #3 You can mount it any way you like. That valve is designed to hold hundreds of pounds of pressure. Mounting it upside down won't make it leak.
