Adjustable rockers a few questions.
Where does pushrod oiling come from? Only in banana groove shafts?
The pushrod oiling comes from the oil that is around the shaft underneath the rocker arm coming out of that little hole on the adjuster side it runs around the adjuster there's kind of a cup made into the rocker arm there and that runs down on to the pushrod.
I highly recommend plugging that outside machine hole on the adjuster side of the rocker arm. That is just an escape point for the oil that is trying to work its way down to the pushrod. That hole was put there so they could drill into the center of the rocker arm to get oil from the shaft to oil the pushrod.
Thanks guys, great info. I'll do the mods when the time comes. Thanks!
Here is what you can do.
Once you have the valves in the heads.
Take and assemble the rocker arms on the shafts on the head with the spacers if it uses them, with the adjusting screws out.
Tighten the bolts that hold the shaft.
Push the rocker arm against the spring.
Now stick a nail or scribe thru the small machine hole on the back side of the rocker where the adjuster goes and mark the rocker arm shaft.
Mark all 16 then use a drill press and drill a 1/8 in or smaller oiling hole.
Take the end plugs out of the shafts so you can clean them real good.
Now the second part.
But the shafts on the head upside down without any rockers on them.
It's now time to banana grove them.
A triangle file can do this.
The groove is not very big. You don't want a big grove or you will have oil leaking out from under your rocker arms.
A pair of rocker groves are opposite each other. \ / or /\
From the same hole.
The greatest load on those rocker arms is on the bottom where you need the banana grooves. Every bit of the spring pressure that is holding against that valve is pushing against the bottom of that rocker arm shaft.
Let me rephrase that.
The greatest load against the rocker arm shafts is at the bottom where the banana grooves are.
The greatest load on the rocker arm is going to be at the rocker arm tip or at the tip of the adjuster. Remember we are multiplying by the rocker arm ratio here. And there is a change of angle in the pushrod at the adjuster.
exactly. The greatest pressure is concentrated on bottom of shaft, just slightly outboard of the attaching holes in the shaft. I can tell you from painful experience that is where they'll gall up from improper lubrication. The dealership mechanic re-installed mine incorrectly and not only ruined the rockers & shafts, but oil pump, bearings, crank, cam & lifters. Get it right or pay the consequences.
I don't know if this helps at all with the oiling hole alignment .
IMHO......You need 2 sets of holes when running adjustables with hydraulic lifters. One hole keeps the pushrod cup oiled and the unloaded part of the shaft, and the other with the banana groove keeps the loaded side of the shaft oiled. I ditched my single hole shafts when I saw evidence of heavy wear exactly where the second hole and the banana groove should be.
Hey Troy, this is for solid lifters and adjustable rockers. I knew something wasnt "right" when I was looking at them. 1 step forward and 3 backwards. :BangHead:
Ok, so thinking about tapping the holes on rocker arms. If the interference fit is in the rockers, why doesnt the jam nut currently thread all the way onto the adjuster??:BangHead:
You don't HAVE to have two holes. The pushrods will get oil regardless. The oiling hole you have causes the rocker to ride on a pressurized cushion of oil. That oil makes its way around to the oiling holes in the rocker, regardless of whether an "extra" hole is there, or not. Now, what "I" would do is get the whiz wheel and banana groove the shafts at the oiling holes you have. That will allow oil to get into a much larger surface area. @prorac1 and @Prorac2 will chime in and show you the great job they did on theirs....IF they're payin attention. LOL
Reading all of this has got me confused about my current configuration. The way I just pulled my rocker shafts and adjustable rockers was the drivers side of the engine has the notch cut out at the firewall and the oiling holes at about the 5:00 position pointing at the exhaust side of the head and banana groves at the bottom of the shaft. The passenger side has the notch towards the front and the oiling holes at about the 7:00 position with the banana groves at the bottom and the oiling holes pointing at the exhaust side of the head. If I turn the shafts around or swap the sides the geometry will never be correct if the notches are supposed to be the opposite way. These shafts and adj rockers were installed on my 70 340 way before it was mine.
On our 67 273 stock adjustable setup we put notch down and to the left for both sides(when leaning over fender). I had purchased another used adjustable set for my 70 340 build. I finally got around to checking them out and this is why I started the thread. I would take off your valve covers and inspect to be sure. Cost you a set of gaskets to be sure.
If they have notches, the notch is down and to the rear on the passenger's side and down and to the front on the driver's side. What will they look like if you do that?
All the "notched" ones I've seen this is true, down and to the left.
I can't say the same about the shafts with the half round or ground on looking cut outs.
And yes some 273s only had 1 set of holes on the bottom of the adjustable rocker shafts.
The bottom hole is on the valve spring side of the pedestal when mounted.
All the "notched" one I've seen this is true, down and to the left.
Yeah, evidently there was more than a couple of different styles.
If I line up the notches as you explained the oiling holes which i only have one row would be pointing to the pushrod side and not the valve spring side. Aren't the oiling holes supposed to be pointing to the 5 oclock position on drivers side and 6 oclock in passenger side?
Then turn the shaft around.
