Adjustable strut rods post-install thoughts
So maybe I'm an idiot. If so the OEM engineers were too. The rubber bushings remained the same and worked just fine for what? 40 year models? Maybe there is a legitimate "curve carving" need for plastic bushings, along with the greasable pins, and adjustable strut rods. Aftermarket will fill most every need one can imagine, fancy shocks, low ratio steering gear, etc.., etc... None of that is for me. My 67 A drives just like a 67 A on the street, and I enjoy it, manual drum brakes and all.
There's the issue, depends on your definition of "just fine"... Also take into account that the OEM engineers didn't have the final say in what components went into the cars, it was the management and bean counters. We're talking about '60s mass-produced American cars not high-end German sports sedans lol. Mopars were better than Ford and GM but far from perfect.
FWIW my Duster doesn't feel like a modern car, it just handles more like one with the suspension upgrades I've done. The best way to describe it is "a battle tank on rails".
One more thing, polyurethane is an "elastomer" not a plastic. Delrin is technically a plastic but "Typical applications for injection-molded Polyoxymethylene [trade name Delrin] include high-performance engineering components such as small gear wheels, eyeglass frames, ball bearings, ski bindings, fasteners, guns, knife handles, and lock systems. The material is widely used in the automotive and consumer electronics industry." Not the same kind of stuff kids' toys and model cars are made out of lol.
If my memory serves, the Barracuda fender had only one brace, made of flat metal, near top center of the wheel well. Should be simple enough to add a brace from front lower corner toward the bumper brace bolts on frame rail. Oh wait... Does the aftermarket not offer that too? If not, Most any pickup truck in the bone yard will have braces under their rear fenders. Good luck with it.
The OEM engineers were not idiots. They needed an assembly process that was simple and easy to perform, and parts that were cheap and easy to manufacture. Installing the stock strut rods and bushings takes no time at all and is easy to perform for even the less than average assembly line worker. There are no adjustments, everything gets pressed home and torqued to spec. All the parts can be the same, same length strut rods for everything, no adjustments, no tuning for bind, just install and torque. The play in the OE rubber bushings makes that good enough for most cars to get to the factory alignment specs, and that's all that mattered. "One size fits most". The factory does things for a lot of reasons, but the bottom line is a big factor, so low production costs for the parts and ease of assembly on the line play a big role. Sometimes a much bigger role than performance, which was especially true when these cars were built.
But the play in the OE rubber bushings that allows the suspension to get away with a "one size fits most" non adjustable strut rod is called SLOP by anyone doing anything that resembles performance driving. That flex allows the LCA to flex forward and backward with the bushings. No, it isn't much, but a little flex adds a lot to the vague handling feedback you get from the stock parts. If you're happy running drum brakes and pizza cutter sized tires you probably won't ever notice it because you don't have enough grip to show it. And you're probably not running a more modern alignment that improves the driving experience with radial tires either. The stock alignment specs will also mask some of that flex. But if you enjoy a crisp handling Mopar, those easy to install, non adjustable parts are contributing to the sloppy handling that a lot of people blame on the suspension design. And really, its not the design. A few upgraded components can get rid of the majority of that slop. But those components also have to be more accurate, they have to be properly installed, and they need to be tuned to the car because they don't have the wide tolerance range of the rubber parts. You can't just slap them on, you have to make it right.
It's about application, just like anything else. Drive around like grandma mopar with skinnies and drums and tiny little torsion bars and you will probably never see the specific shortcomings of some of the original suspension components beyond the atrocious overall handling of your car. If your happy with the oxymoronic "musclecar handling" performance, that's fine. Upgrade your tire compounds so your car can pull .9g on the skid pad and all of that slop, body roll and flex will be readily apparent. It doesn't mean the factory engineers were idiots, nor does it mean that the additional tuning and adjustment needed to run better parts somehow makes them inferior. I've put tens of thousands of miles on my adjustable strut rods and poly bushings on multiple cars, they hold up just fine.
I have RMS front strut rods, and I noticed a sight pulling to the left, when on the gas. It reminded me of when I over tightened the stock ones, it would wander side to side at 20 mph. On the hyway at 70 mph it sort of bump pulls to the left. So I inspected the adjustment, and was easily able to wind the driver's side rod one thread longer and match the 9 threads on the other side. The toe-in increased 1/16". Camber is in at the top 89.80* or less, it should be 89.50 *. I will readjust after I take a spin. I think stressing that shorter is more caster is deceiving. Free up and down, travel is the key.
I have the Helwig hollow front sway bar. KSB? front gas shocks. Willwoods, New big tie rods, 16:1 aluminum box. I might go for the un-sprung Firm Feel rear bar, soon.
Oh I agree, no binding at the LCA in it's range of travel is the most important thing with the strut rods. But on the ones I've installed with poly bushings no binding has also meant shorter than stock and more caster. I didn't install them to get more caster, I installed them so I could have bind free LCA travel and properly located LCA's. But I did get more caster as well, otherwise the maxed out caster setting on my Duster wouldn't have been over +8* with non adjustable UCA's. I had to dial back the +caster because of the 16:1 manual steering and 275/35/18's up front, I run -1* of camber, +7* caster and 1/16" toe in. That's with gusseted stock LCA's, non-adjustable tubular magnumforce UCA's, poly LCA bushings w/greasable pins and adjustable strut rods. Nothing all that fancy, not compared to the SPC adjustable arms and QA1 LCA's with Delrin bushings I'll have installed on the next go around.
