naji408
Just bought a T56 Magnum GM with the close ratio gears. (http://www.hurst-drivelines.com/?page_id=4420&id=9) I'm going to be changing out my ring and pinion also to a 4:10 (I have 3:55s now) with 26" tires.
My question is, I already have a hydrualic clutch system set up for my A833, can I put a Viper throwout bearing with my Quicktime-6076 or is that not possible? If I can, what kind of spacers will I need. Just want to see if I can save a few bucks. Also, will my existing pilot bearing I have been using on my A833 work, or will I have to change that too?
BTW, It has a 408 stroker with 531 torque and 506 hp.
Any input would be awesome, including advise on set-up and gear ratios. Thanks
